I have created a StackBlitz sample for you reference. Please test it on your side and let me know if it meets your requirement.
I have created a sample in StackBlitz for your reference. Please test it on your side and let me know if it meets your requirement.
Additionally, Ignite UI for Angular also provides styling for the input of type="file" and it supports all the input group types and themes, just add this to your template:
More information can be found here.
Thank you for the feedback. I will notify our development team about this issue.
I am glad that you have resolved your issue.
What I can suggest is to take a look at this online sample where an approach for switching to a different series is demonstrated.
Additionally, I have modified the sample for your reference.
You will need to use the notifyRemoveItem method. This online sample might be of help to you. Additionally, I have created and attached a small sample using the notifyClearItems method.
You can use the above-mentioned methods and a couple of more, specified in our API documentation.
About the events for loading data in igDataChart, what I can suggest is to take a look at this forum thread.
Hi Nahush,
I have created and attached a small sample trying to reproduce the behavior that you are experiencing. On my side, everything works as expected. The 4 hidden columns are not added when the resizing feature is enabled.
Please test it on your side and let me know how it behaves.
If this is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me for further investigation.
Exporting to XLSX format could be achieved with our current supported products. I believe you might consider this topic helpful.
For adding filtering to columns or auto change field widths, my suggestion is to use igGridExcelExporter.
Please note that according to our product lifecycle version 11.1 is no longer eligible for support and maintenance. What I can recommend is to upgrade to a newer version in order to take advantage of issue fixes and all new features and components that we have introduced in our latest versions.
