Mike,
I'm working with customizing the ultra combo box for the first time. My application's DLL has a wrapper function set that deals with the underlying Infragistics controls.
What I need to do is set the dropdown portion of the control to have a total width of 800. Column 0 = 10 (doesn't matter because it is hidden) and Column 1 = 790.
The problem I am having is determining how the code should look to set the width. I've tried this but it doesn't do a thing:
With cmbLookupAward
.DataSource = Nothing
.DataSource = setGridData ( SQLStatement ) ' setComboBoxData
.DisplayLayout.UseFixedHeaders = False
'.DisplayLayout.Bands(0).ColHeadersVisible = False
'.DisplayLayout.Bands(0).Columns(0).Hidden = True
.DisplayLayout.Bands(0).Columns(0).Width = 10
.DisplayLayout.Bands(0).Columns(1).Width = 800
End With
So I'm guessing there is a global drowdown width property or something like that that I'm missing?
Could you provide the actual code to do it? For example, What object level contains the DropDownWidth property?
Paul
