Thank you for posting! Currently you can’t use the pager outside the grid. However you can render your own pager and use paging’s API to make it work like the original one. If you don’t want the original one you can cancel the pagerRendering event.
I hope this helps!
Kind regards, Petko Zhekov Software Developer
Petko Zhekov
answered on Jul 3, 2015 2:32 PM
Hi Muhammad,
Can you send us a small project with sample data which demonstrates the issue. This will helps us debug it and find you a solution quickly.
