Pree Khanna
Pree Khanna answered on Apr 29, 2016 8:37 AM
Thank you for the reply.
I had solved the issue using below lines of code:
var gridId = evt.target.id;
var columnIndex;
if(gridId == "ProjNew_Index")
for(i = 62; i < ds.length; i++)
columnIndex = $("#" + gridId + "_" + "REASONS").data("columnIndex")-1;
$(grid.igGrid("cellAt", columnIndex, i)).css('background-color', 'gray');
Thank you
Pree Khanna
Pree Khanna answered on Apr 21, 2016 6:52 AM
Please suggest some solution.
Pree Khanna
Pree Khanna answered on Apr 18, 2016 9:11 AM
Hi Tsanna,
Thank you for the reply. With your help and suggestion I am able to solve the issue.
Below lines of code worked for me:
var columnIndex;
columnIndex = $("#" + gridId + "_" + "col_Name").data("columnIndex");
Thank you so much for the help.
Pree Khanna
Pree Khanna answered on Apr 13, 2016 9:42 AM
Hi Tsanna,
Please let me know what is "gridID_columnKey" in your code ? Do I have to append both gridID and ColumnKey and pass here or anything else that I am unable to understand ?
And when passing "gridID_columnKey", how am I getting the respective CELL here (for which i have to change the background color), as the current value is for Column not for Cell ? Please correct if my understanding is wrong.
Waiting for the reply.
Pree Khanna
Pree Khanna answered on Apr 13, 2016 6:59 AM
Hi Tsanna,
I tried below javaScript code to achieve the desired requirement, in respective View(Index.cshtml):
function changeCellColor() {
debugger;
var gridId = evt.target.id; //getting gridId of respective controller
if(gridId!=null && gridId!=undefined)
var column = grid.igGrid("columnByKey","EXPD_HDR_VARIANCE_REASONS"); //getting column key
$(gridId).find("td[aria-describedby=" + column + "]").css("background-color", "red"); //code to change background color
In above code, I am able to get the gridId, columnKey but please let me know how to pass the specific cellKey to change specific CELL background color, in my above code ?
Also, when I am trying the same code to change the color of column(just to test the code) it never change the background color.
Please let me know what is wrong in my code ?
Looking forward for the reply. Thanks in advance.
Pree Khanna
Pree Khanna answered on Apr 13, 2016 4:45 AM
Hi Tsanna,
Thank you for the reply. I am trying your suggested method. Will update you soon.
