We are using 2014.2 with SR2590.
We are moving from VS2013 to VS2015, but the Create ASP.NET Toolbox Tab for CLR 4.5 2014 says VS2015 is not supported.
Do we have to upgrade Infragistics to work with VS2015?
A product with the specified parameters was not found on the system or it is not supported in Visual Studio version 14.0. No folders containing assemblies were found.
Products that were successfully run:
ASP.NET product 14.2 CLR45 was successfully run with Visual Studio 2013.
Products that were unsuccessfully run:
ASP.NET product 14.2 CLR45 was unsuccessfully run with Visual Studio 2015.
Hello dc06663,
Thank you for posting in our forums!
Our Supported Environments page shows that we do not support VS2015 until Infragistics 15.1. You may still be able to manually add the 14.2 controls to the toolbox in VS2015 through the "Choose Items..." dialog, but we do not guarantee that all functionality will work with VS2015.
I would recommend upgrading to Infragistics 15.1 or newer. If you have any further questions or concerns with this, please let me know.
