815
nuget feed responding with Anonymous Login Not Allowed
I updated my nuget source with the correct username and password but I still get this issue. Can I download the package files from the website rather than use the nuget feed?
source\repos\TOD_Infragistics\TOD_API> dotnet add package System.Linq
Writing AppData\Local\Temp\tmp21BC.tmp
info : Adding PackageReference for package 'System.Linq' into project '\source\repos\TOD_Infragistics\TOD_API\TOD_API.csproj'.
info : Restoring packages for \source\repos\TOD_Infragistics\TOD_API\TOD_API.csproj...
info : GET packages.infragistics.com/.../FindPackagesById()
info : GET api.nuget.org/.../index.json
info : OK api.nuget.org/.../index.json 544ms
info : Unauthorized packages.infragistics.com/.../FindPackagesById() 3076ms
log : Retrying 'FindPackagesByIdAsyncCore' for source 'packages.infragistics.com/.../FindPackagesById()
log : Response status code does not indicate success: 401 (You are not authorized to view this feed because the user Anonymous does not have the Feeds_ViewFeed privilege.).
info : Unauthorized packages.infragistics.com/.../FindPackagesById() 1982ms
info : Unauthorized packages.infragistics.com/.../FindPackagesById() 3004ms
error: Failed to retrieve information about 'System.Linq' from remote source 'packages.infragistics.com/.../FindPackagesById()
error: Response status code does not indicate success: 401 (You are not authorized to view this feed because the user Anonymous does not have
  • 29105
    Hello Eric,
    Thanks for reaching out. We are aware of this happening. I've reported an issue #264909 to our engineering team. I should hear back shortly. I'll transition this to a private case, CAS-20298 where you can visit within your account's support activity section.
