Can you confirm that your nuget feed is available?
https://packages.infragistics.com/nuget/licensed
When trying to access this using the package manager console I am recieving the following error:
[Infragistics] The V2 feed at 'packages.infragistics.com/.../Search() returned an unexpected status code '500 Internal Server Error'.
Any help would be appreciated.
Thanks, David
Hello David,
Thank you for informing me of your progress. Let us know if you need any further assistance.
Yes, it looks like your side is up and running.
As you can see above, I'm still having tons of trouble getting my nuget packages to download to one of my workstations. I think it is because of an https-inspection software package that we use called zscaler. I'm still working with our I.T. department on that....
In any case thanks for the help. Hopefully your feed will stay up and running long enough for me to get help from I.T. and get back to programming again...
Please check again. The issues we had this morning have been addressed.
Thanks for the reply.
I was looking for WPF 18.2 (current service release) and hoping to follow along with some of the tutorials that Brian Lagunas had put together about using WPF with the new core 3.0. In theory I should be able to use your controls in a core 3.0 app but have yet to attempt that myself.
Its not that critical. I probably won't have time to play with it again until next weekend anyway. If you can get the nuget server back up before then it would be sufficient.
Otherwise I can log into my account on your support site as well ... but I couldn't see where you put nuget packages. Are they available for download in there as well?
We are currently having technical difficulties with our Nuget server. Which platform/volume release/build are you looking for? I can send a link over to you directly in the meantime to download the NuGet packages.
