385
Azure pipe line set up
We are using infragistics "@infragistics/igniteui-angular": "~13.2.16" in our packge.json file.
We generated the token for one of the user accounts, and configured registry, username (email), token and always-true in .npmrc file.
Also, we have configured the varibales in in the pipeline. (as per the link https://ko.infragistics.com/products/ignite-ui-angular/angular/components/general/ignite-ui-licensing#azure-pipelines-configuration). But still, when the CI pipelines runs, it fails with below error
Error during npm install in Azure DevOps CI pipeline
GET 401 https://packages.infragistics.com/npm/js-licensed/@infragistics%2figniteui-angular 523ms (cache skip)
npm verb stack HttpErrorGeneral: 401 Unauthorized - GET https://packages.infragistics.com/npm/js-licensed/@infragistics%2figniteui-angular - Unauthorized
If we relace "~" with "^", then it is giving 404 error.
npm http fetch GET 404 https://registry.npmjs.org/@infragistics%2figniteui-angular 245ms (cache skip).
It is working fine locally. Can you please let us in this, how can we download the package in azure pipeline?
