1255
XamSpreadSheet Error
If I enter a bad formula into the WPF XamSpreadSheet, such as "=sum(1+...+50)", I get an endless display of error dialogs and am not able to clear or continue working on the formula.  For all practical purposes it locks up our software.
How can I get out of this endless loop.
Richard
    Consider restricting the user input for formulas by validating formulas before they're entered into the cell. This would prevent invalid formulas from being submitted in the first place.
    It sounds like you're running into an issue where entering an invalid formula in the WPF XamSpreadSheet results in an endless error loop that prevents further work. To resolve this issue, you can consider the following strategies:
    1. Handle Errors Programmatically
    You can prevent the endless error dialogs by handling formula errors in your code. Use the FormulaError event to catch invalid formulas before they trigger an endless loop.
    Example:
    xamSpreadsheet.FormulaError += (sender, e) =>
        // Handle the formula error (e.g., display a custom error message)
        e.Cancel = true; // Prevent the default error dialog
    This way, the FormulaError event can intercept any invalid formulas, and you can manage how the errors are handled instead of letting the default behavior take over.
    2. Programmatically Remove the Invalid Formula
    If you are stuck in the formula editor, you can clear the formula programmatically (without needing to interact with the UI) when such an error occurs.
    Example:
    // Assuming xamSpreadsheet is your XamSpreadSheet control
    xamSpreadsheet.CurrentCell.Formula = ""; // Clear the formula programmatically
    This clears the invalid formula and allows the user to continue working without being blocked by the error.
    3. Restrict Formula Input
    Example:
    xamSpreadsheet.EditingStarted += (sender, e) =>
        var formula = e.Cell.Formula;
        if (IsFormulaInvalid(formula)) // Define a method to check formula validity
            // Handle invalid formula input
            e.Cancel = true; // Cancel the editing process
            MessageBox.Show("Invalid formula entered.");
    This will stop users from entering problematic formulas, avoiding the endless error loop.
    4. Enable Formula Validation
    If possible, implement more robust formula validation. Check the formula structure before it gets executed or rendered. This can prevent certain types of invalid inputs from being processed by the XamSpreadSheet.
    5. Use Try-Catch for Error Handling
    Another approach could be wrapping the formula evaluation logic in a try-catch block to handle any unexpected errors more gracefully. If the formula is invalid, you can catch the exception and handle it appropriately (e.g., by showing a custom error message and clearing the formula).
    Example:
    try
        // Formula evaluation logic
    catch (Exception ex)
        // Handle the exception (e.g., clear the formula or show a message)
        xamSpreadsheet.CurrentCell.Formula = ""; // Clear the invalid formula
        MessageBox.Show("Error with the formula: " + ex.Message);
    6. Reset Formula Using Keyboard Shortcuts
    If the dialog is blocking the interface, try using the Esc key or Ctrl+Z (Undo) to cancel the operation and return the spreadsheet to a functional state.
    7. Disable Error Dialogs Temporarily
    If the error dialogs are becoming a problem, you can disable them in the settings for the XamSpreadSheet control and handle the errors programmatically as described above.
    By implementing one or more of these solutions, you should be able to stop the endless loop of error dialogs and get back to working in the spreadsheet. Let me know if you need more detailed code examples or further assistance!
  • 7635
    Offline posted in reply to Richard Carlin
    Hello Richard,
    I am able to get the same behavior with MS Excel as you explained but not with XamSpreadsheet.
    To test this scenario i use your excel sheet .BadFormula.xlsx and load it into XamSpreadsheet and not able to reproduce the behavior you described.
    I attached my test sample here for your reference , if i am missing something please feel free to modify it and send me back for further investigation.
    WpfApp14.zip
  • 7635
    Try to use the same formula to MS excel and test what is the behavior you are getting ? Is it different ?
    Can you share your excel containing the formula so that i can try to load it into XamSpredSheet to test it or you can also share your own sample to investigation it .
