The same problem again and again. After publishing the PDB files in version 8.1, Infragistics initially forgot to publish them in 8.2. The issue was discussed at http://news.infragistics.com/forums/p/10771/41123.aspx , and PDB files were published at the end of the day. Now they are again missing in 8.3 release. Infragistics support claims, that the PDB files must not be there and files our issue as feature request FR10724. We desperately need these files, and I’ve already discussed twice the necessity of publishing of PDB files. Please, publish them as soon as possible
(and make some kind of rollout script. Or at least write down on a piece of paper things need to be done before release).
Ed,
Could you please mention location of the newly published sources and corresponding PDB files for ASP.NET assemblies from the Infragistics NetAdvantage ASP.NET 2008 Vol3 for CLR3.5 release?
Thanks. -DS.
Thanks for the update. It looks like you have a support case open with Vince so I'll work with him to get you updates.
That was a bit too quick. The pdb file for UltraWinChart is absent. It would be great if you could update the published source code
Let me check with our Web Team to see when it will get published... Thanks for your patience.
