145
Tracker Demo Application
 The tracker application was built with an earlier than the NetAdvantage 7.3 suite.
Is the source code for this sample application also available to use in Visual Studio 2005 and the latest set of controls that we have bought (=7.3) ?
 Or can we download the trial version of the NetAdvantage suite which the Tracker app was built with (I can't find a link) ? So that we can 'open' the forms in VS2005 without these errors :
ErrorImage One or more errors encountered while loading the designer. The errors are listed below. Some errors can be fixed by rebuilding your project, while others may require code changes.
The designer cannot process the code at line 292: Dim Appearance1 As Infragistics.Win.Appearance = New Infragistics.Win.Appearance The code within the method 'InitializeComponent' is generated by the designer and should not be manually modified. Please remove any changes and try opening the designer again.
Hide    Edit
at Microsoft.VisualStudio.Design.Serialization.CodeDom.XML.CodeDomXmlProcessor.CreateQuoteExpression(XmlElementData xmlElement)
at Microsoft.VisualStudio.Design.Serialization.CodeDom.XML.CodeDomXmlProcessor.XmlElementData.get_CodeDomElement()
at Microsoft.VisualStudio.Design.Serialization.CodeDom.XML.CodeDomXmlProcessor.EndElement(String prefix, String name, String urn)
at Microsoft.VisualStudio.Design.Serialization.CodeDom.XML.CodeDomXmlProcessor.Parse(XmlReader reader)
at Microsoft.VisualStudio.Design.Serialization.CodeDom.XML.CodeDomXmlProcessor.ParseXml(String xmlStream, CodeStatementCollection statementCollection, String fileName, String methodName)
at Microsoft.VisualStudio.Design.Serialization.CodeDom.VSCodeDomParser.OnMethodPopulateStatements(Object sender, EventArgs e)
at System.CodeDom.CodeMemberMethod.get_Statements()
at System.ComponentModel.Design.Serialization.TypeCodeDomSerializer.Deserialize(IDesignerSerializationManager manager, CodeTypeDeclaration declaration)
at System.ComponentModel.Design.Serialization.CodeDomDesignerLoader.PerformLoad(IDesignerSerializationManager manager)
at Microsoft.VisualStudio.Design.Serialization.CodeDom.VSCodeDomDesignerLoader.PerformLoad(IDesignerSerializationManager serializationManager)
at System.ComponentModel.Design.Serialization.BasicDesignerLoader.BeginLoad(IDesignerLoaderHost host)
kind regards
Yves
