We have a license for NetAdvantage for .NET 2008 Vol. 2 CLR 2.0 Corporate (With Annual Subscription Service).
Could you tell me please how can we upgrade the product to NetAdvantage for .NET 2009
Volume 1?
Flor María Fernández
flormaria.fernandez@jtechconsulting.com
Hi Flor - Thanks for reaching out to us and Daryl - thanks for the assistance.
If you log in and go to My IG > Keys and Downloads and under NetAdvantage you'll see your 2009 v1 key. Our system already registered for you so you just have to click on the key to begin the download process.
As to actually upgrading your project, there is an Upgrade Utility that can be found from your Start Menu and you simply select the versions you're upgrading from and to and the utility will migrate the code for you. If you didn't do anything special on the front end, the migration should go smoothly. If you do need assistance my colleagues can help you either here in the Forums or through Developer Support, http://ko.infragistics.com/support/submitrequest.aspx.
DebbieK
You should get notification from Infragistics.
If not go to the Support site, and select MY IG. That should show you the versions and the keys.
