I was curious if an Install on a Virtual PC was allowed? I found a work around but I could not do the initial Setup using a CD Key. I installed as a trial and then did an upgrade which got it to work.
I kept receiving the invalid CD Key when I was doing the initial install.
which version of Virutal PC you use Virutal PC 2007 or Windows Virutal PC?
