Here is a error, when I am trying install NetAdvantage 2005 Volume 1 in my new Window 7 os:
Error 1609. An error occured while applying security settings.ASPNET is not a valid user or group.This could be a problem with the package, or a problem connecting to a domain controller on the network.Check your network connection and click retry, or Cancel to end the install.
Is anyone know the answer?
I just tried to follow this post trying to install Hotfix 1 on windows 7 and getting same error.. However no one has responded to the last error.
Maybe the compact and the SDK are not enough? Try to download the framework and install it.
Yes, I have Microsoft .NET Compact Framework 2.0 SP2 and Microsoft .NET Framework 2.0 SDK (x64) installed
Do you have framework 2.0 installed?
Hi Amiram,
I have a license and I have downloaded the NetAdvantage 2005 Volume 1 Hot Fix msi.
But when I am trying to install it, having the error message "Windows can't find 'gacutil' file..." , stopping installation process and restarting my Window 7 os.
Please advice. Thanks
