445
Upgrading Infragistics WPF library Volumes and Patches
Hi all,
We have at least 50 solution and 500 UI project which use Infragistics WPF references. When we want to upgrade to new volumes it is a big problem for us. Becouse new volumes get new dll names and new signature.So we have to install new volumes first and remove all dll references from all projects and add them all again. It is a very painfull process for us. What would you recommend us to get rid of this process. Is there any easy solution for upgrading new volumes ?
  • 8607
    Hello emreo,
    NetAdvantage products contain a Version Utility application, which should allow you to upgrade projects without having to manually remove old dlls and add new ones.
    You can find out more about the Version Utility in this help topic.
    Elizabeth Albert
    Localization Engineer
