Can anyone help with registering old versions?
As per IG's sales instruction I requested old versions of the software on the order form.
“Please note we need the back version of this which includes IGThreed40.OCX version 4.0.1.6, SSInput1.ocx v 1.0.1.30,
sstree.ocx v1.0.4.6 and PVTaskPad.ocx v 8.0.3.6”
On running the install the old (ultrasuite) and new (ultrasuite 3.02) versions are on my PC but only the new versions are registered... when I try and reference the old OCX’s I get for example from VB6 “SSINPUT1.OCX was not registerable as an OCX component”. When I try and manually register the component using REGSVR32.exe I get an error of 0x8002801 c.
Thanks all!
Hello:
I am happy to assist you.
UltraSuite 3.02, which consists of the IGThreed4.0 ocx file, is part of our retired COM (VB6) product line. In order to remove the referenced licensing error, you will need to ensure that any prior version has been removed from your machine. You may then reinstall directly from our website.
In regards to your current Operating System- Infragistics did not offer Windows 7 Compatibility until our NetAdvantage 2009 Volume 2 version, which requires .NET framework.
For additional questions, or concerns, please contact registrations@infragistics.com.
Marie DiPoalo
Customer Support Manager
A bit more information though I still need a solution...I'm using Windows 7. Hopefully this should not make a difference.
As an update I have managed to register the new old versions of the components but twhen these are chosen in VB I still get the nag /unregistered message. If I try to browse to the OCX's in question VB says they are unregisterable. Help please!
