hi
i've downloaded from site and executed NetAdvantage_Help_20083_CLR20.exe.
it exits successfully but nothing comapre in local Help files.
Forum suggest to add manually but i can't find any .msha files...
In C:\ProgramData\Microsoft Help i can find a lot of files newly installed :
INFRAGISTICS_NETEN83CLR2_HELP_1033_MValidator.Lck
INFRAGISTICS_NETEN83CLR2_HELP_1033_MKWD_NamedUrlIndex.HxW
..and so on...
but i can't use or open in VS2010
Any suggestion?
thanks
Were you able to install the 2010.3 VS2010 help?
Although it's not as convenient as context-sensitive help, another alternative is to use the online documentation.
You should be able to download the NetAdvantage 10.3 VS2010 help without a license key. I don't have any registered license keys and I can download it from the website after signing in. The installer doesn't ask for a license key, so there shouldn't be a problem there.
Could you try to download the 10.3 VS2010 help? It's the first link under "Documentation & SDK" on this page.
Thanks elisabeth
about your points:
1. It's exactly what i'm doing, but i have to install VB2008 only for this. More, using help in the context permit to jump to the right place, not searching from index everytime... and my project is in VS2010 , so i can't do it
2. I haven't a licence for 2010 components, only for 2008v3, so i can't download the VS2010 version for NetAdvantage 10.3 help files...
i can understand your company point of view, but it's a pity.
thanks anyway
Hello alexponti,
The help files you have downloaded cannot be loaded in Visual Studio 2010. This is because Visual Studio 2010 uses a different help format than Visual Studio 2008. There are two options:
1. You can view the 2008.3 help locally in Visual Studio 2008.
2. You can install a newer version of the help (like the VS2010 version for NetAdvantage 10.3) regardless of whether or not you're using the controls from that version.
Elizabeth AlbertLocalization Engineer
hi elizabeth
i've already seen the pages you refers to, where you can download Infragistics2010 components.
but i'm trying to install infragistics 2008v3 help files in visual studio 2010.
The help files format 've downloaded can't be loaded in visual studio 2010, or i miss something?
