Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
Regarding the Infragistics MAP Control
I would like to know one important feature of the MAP Control, In case of India if I zoom the Maharashtra then I should get the list of all the districts and on district zoom I am will get the taluka zoom.
In case of USA if is select the area I am suppose see the county, on zoom of county I am suppose to see the City Map.
Let me know the feature is available or not.
Yes, this is available. It will work 'automatically' with the OpenStreet tile service, or you can apply various SHP files to the Layers collection of the map.
This samples shows how to use multiple layers of SHP files:
https://ko.infragistics.com/samples/silverlight/map/#/multiple-layers
This sample shows how to use the OpenStreet tile service:
https://ko.infragistics.com/samples/silverlight/map/#/binding-to-geo-imagery-data
Both methods are extremely simple to implement, let me know if you need any more info to move forward.
Jason
