I can't seem to upgrade my project to 2011.1. Following is the log file:
11:10:30: Gathering volume and assembly information.11:10:37: ProjectFile element: SOS_SalesPlanner\SOS_SalesPlanner.vbproj is being treated as a proj file.11:10:37: Analyzing SOS_SalesPlanner.vbproj...11:10:37: The following project needs to have its references updated: 11:10:50: Gathering volume and assembly information.11:10:52: ProjectFile element: SOS_SalesPlanner\SOS_SalesPlanner.vbproj is being treated as a proj file.11:10:52: Analyzing SOS_SalesPlanner.vbproj...11:10:52: The following project needs to have its references updated: 11:10:55: Upgrading Solution SOS_SalesPlanner.sln11:10:55: Updating SOS_SalesPlanner.vbproj...11:10:55: C:\Projects\SOS_SalesPlanner\SOS_SalesPlanner\SOS_SalesPlanner.vbproj has been backed up.11:10:55: Object reference not set to an instance of an object.11:10:55: at Infragistics.VersionUtilitySupport.Core.File.Utilities.ProductUtilities.GetAssemblyName(String str) at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Upgrade(String rootDirectory)
I have tried to use the Upgrade addin as well. Different error but still does not work.
11:16:38: Gathering volume and assembly information.11:16:39: ProjectFile element: SOS_SalesPlanner\SOS_SalesPlanner.vbproj is being treated as a proj file.11:16:39: Analyzing SOS_SalesPlanner.vbproj...11:16:39: The following project needs to have its references updated: 11:16:43: Index was out of range. Must be non-negative and less than the size of the collection.Parameter name: index11:16:43: at System.ThrowHelper.ThrowArgumentOutOfRangeException() at Infragistics.VersionUtilitySupport.Core.ProductAssemblies.Products.KeepLatestVolumes(List`1 installedNetAdvantageProducts) at Infragistics.VersionUtilitySupport.Core.ProductAssemblies.Products.TrimList() at Infragistics.VersionUtilitySupport.Core.SourceChanger.Upgrade()
Project is currently 2010.3. No source control. I have tried other projects and they seem to go without a problem so this must be project specific. So I guess it is something with this one solution, but I don't have any idea what is causing the problem????
Dan
We have released and SR for the Version Utility today for 2011.1, and you can read more about it at http://blogs.infragistics.com/blogs/engineering/archive/2011/08/22/2011-1-version-utility-installer-re-release-service-release.aspx
Thanks!!!!!
This solution working perfectly after remove the unused references
Sorry to hear that. Are you using the Version Utility Extension in Visual Studio? If so, try the Stand-alone Version Utility; there is a bug on x64 machines where you get this error, and we are working on fix it currently, but it's just in the Visual Studio extensions.
I removed the Gauge reference and Design reference, but still not working.
01:05:16: Gathering volume and assembly information.
01:05:18: ProjectFile element: Sicov\Sicov.vbproj is being treated as a proj file.
01:05:18: Analyzing Sicov.vbproj...
01:05:18: The following project needs to have its references updated:
01:05:21: ProjectFile element: Cuentas x Pagar\Cuentas x Pagar.vbproj is being treated as a proj file.
01:05:21: Analyzing Cuentas x Pagar.vbproj...
01:05:21: The following project needs to have its references updated:
01:05:21: ProjectFile element: ReportServerSicov\ReportServerSicov.rptproj is being treated as a proj file.
01:05:21: Analyzing ReportServerSicov.rptproj...
01:05:21: Nothing for us to upgrade.
01:05:21: ProjectFile element: ReportesCliente\ReportesCliente.vbproj is being treated as a proj file.
01:05:21: Analyzing ReportesCliente.vbproj...
01:05:21: ProjectFile element: smo\VS\SMODemos\SMODemos.csproj is being treated as a proj file.
01:05:21: Analyzing SMODemos.csproj...
01:05:21: ProjectFile element: Instalador\Instalador.vdproj is being treated as a proj file.
01:05:21: The project file C:\Users\Erick\Desktop\SuCasa 2010\Instalador\Instalador.vdproj doesn't appear to be in Xml or is malformed.
01:05:25: Index was out of range. Must be non-negative and less than the size of the collection.
01:05:25: at System.ThrowHelper.ThrowArgumentOutOfRangeException()
Remove the reference to the Design assembly for Gauge. The tool doesn't handle upgrading design references as we don't recommend having Design assemblies referenced in a project. That said older versions of Gauge as well as Chart would add references to there design assemblies. You should be able to remove it, and upgrade without issue.
