How can I see the Source code for the Infra Shop Application fromthe Application sample?
Is their any way? if any then Please help me out..
Hello nvcabhinav,
It is possible to view the source code of the showcases.
When you visit the link below:
http://samples.infragistics.com/aspnet/AppSamplesOverview.aspx#InfraShop
please click on the "Download" button, and on the right hand side groups, there is a group called "Documentation & SDK" where you would be able to download the source code for the showcases.
Please let me know if you need any other assistance.
Thanks Danko Vallkov
But i am facing one more problem .We have upgraded infragistics 10.2 with an service release 2230.After that many things that are running fine stop working now.Best example is Web Dialogue Window.I would really appreciate if you could help me in that too.
Thanks..
Hello rajulg,
I have verified that the latest available service release for NetAdvantage for ASP.NET 2010 vol2 is 2247. So could you please download it from our web site and verify if your issue still exists with it.
I have created the following case for you - CAS-69421-2MBV1C.
If you have the same issue existing after applying the latest service release please provide us more details about your scenario or even a small sample reproducing the issue through the case and we will be glad to assist you further with it.
Hello Danko Valkov,
Thank againg for you help.. We have decided to migrate from 10.2 to 11 .SO after migrating we will definately see that it is woking or not..If we still face the same issue then i will definately get back to you..
Thnaks
