Hi:
I recently upgraded to Windows 7.
I have several applications that were developed using Netadvantage 2005 Volume 2. I still support these applications.
When I tried to install it on the machine, after selectimg the setup type (Complete installation), when I click the next button, I get the "Ready to Install the Application" window. When I click on install, I get another windows that says "Error 1609. ASPNET is not a valid user or group. This could be a problem with the package, or a problem connecting to a domain controller on the network. Check your network connection and click Retry, or Cancel to end the install.."
I know this tool is at least 5 years old and you may say that I will have to upgrade to the latest version. But I cannot say that to my clients.
Can someone guide me on what I should do to get this issue resolved?
Venki
Hello Venki,
As you said, this is not a supported version any more. Please try following things on the machine.
If the above steps do not work, please contact Infragistics support team.
Dinker Abraham
Release Engineering Manager
