When i tried to update a row in 2nd or 3rd page ... i'm getting the following error.
But the update is working fine in 1st page.
Please help me.
TIA
Requested record cannot be found by key.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: Infragistics.Web.UI.GridControls.MissingRecordException: Requested record cannot be found by key.Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
[MissingRecordException: Requested record cannot be found by key.] Infragistics.Web.UI.GridControls.EditingCore.OnAction(String actionType, Object id, Object value, Object tag) +942 Infragistics.Web.UI.GridControls.GridBehavior.Infragistics.Web.UI.GridControls.IGridBehavior.OnAction(String actionType, Object id, Object value, Object tag) +48 Infragistics.Web.UI.GridControls.GridBot.LoadAdditionalClientState(Object state) +682 Infragistics.Web.UI.Framework.RunBot.HandleRaisePostDataChangedEvent() +204 Infragistics.Web.UI.GridControls.GridBot.HandleRaisePostDataChangedEvent() +74 Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.RaisePostDataChangedEvent() +34 System.Web.UI.Page.RaiseChangedEvents() +134 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5201
I am also facing with same error when i upgraded to netadvantage 11.1 clr 3x.
I am not even using enable viewstate...help please??
By Disabling "EnableDataViewState".. i fixed this issue..
Anybody here to help me/???
