710
Migarte from 3.3 to 10.1
I would like to migrate my solution file from 8.3 to 10.1
when I try to do so with version utility I get:
11:52:06: No matching assembly located in available assemblies Infragistics2.Win.UltraWinGrid.v8.3
11:52:06:    at Infragistics.VersionUtilitySupport.Core.ProductAssemblies.AssemblyXmlFile.LocateNewAssembliesNodeforCurrentAssembly(String assemblyName)
   at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.FetchNewAssemblyNode(String assemblyOldName)
   at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Upgrade(String rootDirectory)
11:52:06: ....MainForm.resx has been backed up.
11:52:06: ....LanguageSettingsEditor.resx has been backed up.
11:52:06: An exception occurred while trying to upgrade ...LanguageSettingsEditor.resx.
   at Infragistics.VersionUtilitySupport.Core.File.Types.ResxFile.Upgrade(String rootDirectory)
do I need to migrate through al the version so 2009 first ?
  • 8607
    Hello PoKrec,
    You do not need to upgrade through the 2009 versions.  You should be able to directly upgrade to 10.1.
    I have seen other similar forum posts, and I think this issue has been fixed.  Could you please try to use the latest version?  You can download it here (last link on the right side "NetAdvantage Version Utility").  You could also download the 11.1 platform installer (the first link), which will only download the products you want to install.  You can select the Version Utility, and select to download the latest service release.
    If the project still does not upgrade, please attach the log file to this forum post.  I can forward it to the appropriate developer.
    Elizabeth Albert
    Localization Engineer
