We are using Infragistics dock controls version 2007.2 and are running into an error when trying to parse the "Ø" Norwegian Character.
Can you tell me if the later versions of dock controls are able to handle the Norwegian special characters?
Thank You.
Elizabeth,
That was the issue. We were using default encoding, instead of UTF-8.
Thank you for your response.
Hello rpuser,
Could you check the Advanced Settings of your file (*.cs) to make sure that it is set to Unicode or UTF8?
If this does not fix the problem, please post in the appropriate product and control forum (ex. Windows Forms Dock Manager) so that the developers and support staff will see your post.
Elizabeth AlbertLocalization Engineer
