hi
I have registred key we are using Infragistics 7.2 please let me know how to download and upgrade latest Infragistics version.
Thanks & Regards
Jagdish Kotian
I think you're pushing it expecting v7.2 to work with IE9 or many of the newer browsers. It is highly recommended that you upgrade. Whilst I appreciate the hassle this will cause you, I equally have some sympathy for Infragistics as in 2007 browser standards were still very much still wobbling around all over the place. Still got some wobbling to do but I suspect that if you embraced the new controls now, then upgrading and problems in the future will be much reduced.
Somebody said the web was "Write once, run everywhere". It's a shame they missed off ", run forever" as that's not certain at all.
Cheers, Rob.
We are using Infragistics 7.2 UltraWebGrid control and RowEditTemplate edit rows it was working fine on IE8. There is a issue on IE9 when try to open RowEditTemplate for multiple row from UltraWebGrid getting error as follows :
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; WOW64; Trident/5.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0E; .NET4.0C)Timestamp: Thu, 26 Jul 2012 13:05:12 UTC
Message: Unable to get value of the property 'init': object is null or undefinedLine: 10420Char: 2Code: 0URI: http://10.2.128.5:8080/ScriptResource.axd?d=WZX05j1lplnjYaWOqkGy33gbhXQ09LKVp39K2BkOimsvSh9qHpGXKMxRv8V66fjPpIFBCoVRxF9tDFWERapFQP-xE8joly5US0Y6ClbhW_u2ON1EoFhfUkfMn1k1TaNe6qzZtOIhQ53WsSmaL89FRQ51neL3xf-Y0uP-A10Ox0k1&t=55bc7e4b
Please let me know what is cause of issue.
Jagdish
To download the latest version for NetAdvantage for .NET from our website, please follow these instructions:
1) Navigate to the "Account" page on our website. You may be asked to log in using your Infragistics member profile's user name and password. You can reach the “Account” page via the following link:
<https://ko.infragistics.com/my-account/keys-and-downloads>
2) Click on the "NetAdvantage" tab. This will show all of your registered license keys for NetAdvantage.
3) Click on the version of Product under Product Name for which you would like to download a product version. This will bring up all available public downloads for this product and version.
4) From “Products & Bundles” tab click on the link for the appropriate version of NetAdvantage.
If your license key is not listed on the My Keys and Downloads page in step 2, then your key has not been registered to your member profile. To register your license key, please go to the Product Registration page, via the following link:
<https://ko.infragistics.com/my-account/register-product>
Once your license key is registered, it should appear in the My Keys and Downloads page, thus allowing you to download service releases for that version of NetAdvantage.
Keep in mind that classic controls like UltraWebGrid are retired in NetAdvantage version 2011.2. You will find more details on the product changes in 2011 Volume 2 from the below link:
<https://ko.infragistics.com/community/blogs/b/taz_abdeali/posts/asp-net-product-changes-in-2011-volume-2>
I would suggest you to use our Aikido controls supported across major browsers. You will find more detail on the below links:
<https://ko.infragistics.com/products/aspnet/grids-and-lists/data-grid>
<http://help.infragistics.com/Doc/ASPNET/2011.2/CLR4.0/?page=Classic_Control_Migration_Guide.html>
<http://help.infragistics.com/Doc/ASPNET/2011.2/CLR4.0/?page=Web_WebDataGrid_WebDataGrid.html>
If you are continuing to use classic controls best approach for you is to use versions earlier than NetAdvantage version 2011.2 like NetAdvantage version 2011.1,... You can find the download for NetAdvantage for ASP.NET 2011 Volume 1 on the below link:
<https://ko.infragistics.com/support/archived-downloads>
I hope this helps.
