As I've just mentioned in another post, I'm about to migrate my apps from VS2008 to VS2010 (or maybe VS2012) and at the same type I'm going to be doing a lot of cleaning up of the HTML and CSS. I'm planning to simply use but recommended <!DOCTYPE html> and set the validation to HTML5.
Should I expect any problems/syntax errors with the latest NetAdvantage release?
Cheers, Rob.
PS. I would have put this over in the NetAdvantage for ASP.NET forums but there is no suitable topic. Maybe we need a General category over there?
Hello Rob,
The Infragistics ASP.NET and jQuery controls currently support the following doctypes:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" " http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<!DOCTYPE html>
So you should be fine with the approach that you are taking. If you encounter any issues with the controls please let us know and we can create a support case for you to assist you further. Please let me know if I can be of any further help.
