I have just installed rel. v12.2 and upgraded a WPF project
I get this error : need reference to 'InfragisticsWPF4.v12.1, Version=12.1.20121.2002, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'
I also use Tiles and Reports in this project which is stil at 12.1
Judging by the errors, it looks like you are using the Silverlight control xamTileView that was also deprecated in the 2012.2 release.
You will want to replace the control with XamTileManager. The documentation concerning this control begins at http://help.infragistics.com/NetAdvantage/Silverlight/2012.2/CLR4.0/?page=xamTileManager.html.
This site may also be helpful to you to review although it was created when the control was first released.
http://ko.infragistics.com/community/blogs/atanas_dyulgerov/archive/2011/11/01/xamtilemanager-new-control-in-the-xaml-line-of-business-product-shipped-with-the-11-2-release.aspx
Please let me know if you have any specific questions that I can help you with.
Getting following errors while upgrading 12.2.
Please give solution for the followings.
Error 254 The tag 'TilePaneCommandSource' does not exist in XML namespace 'http://schemas.infragistics.com/xaml'. DashboardStyles.xaml 4588 50
Error 255 The tag 'DropIndicator' does not exist in XML namespace 'http://schemas.infragistics.com/xaml/primitives'. DashboardStyles.xaml 4771 30
Error 256 The tag 'TilePaneCommandSource' does not exist in XML namespace 'http://schemas.infragistics.com/xaml'. DashboardStyles.xaml 4840 50
Error 257 The tag 'TilePanel' does not exist in XML namespace 'http://schemas.infragistics.com/xaml/primitives'. DashboardStyles.xaml 5034 30
Error 300 The member ColumnsInPage and RowInPage are not recognized (XamTileView Property)
Hi Christian,
I am wondering if you have any further questions. Please let me know if there is anything more I can help you with.
Yes, the 2012.2 Ultimate package shipped without NetAdvantage Reporting. We expect that NetAdvantage Reporting 2012.2 will be released sometime in November.
You can, however, go to your account and the 2012.1 NetAdvantage Reporting installer is available when you select the 2012.2 Ultimate product.
WPF Reporting is embedded in WPF and doesn’t share the Reporting assemblies so there should be no conflict if you need to either use WPF Reporting framework in your WPF project or include 2012.1 NetAdvantage Reporting in an otherwise 2012.2 solution, and certainly not referencing an igr file in a xamReportViewer.
What about reports?
the version which ships with 12.2 ultimate is still 12.1
