My organisation has developer licenses for NetAdvantage 2006 which is being used for one of our projects. Whilst checking for Windows 7 compatibility on the application, I get a License Exception (Trial period expired) error on the Infragistic components when project is opened in VS 2010 (under Win 7). The same works ok when opened in Win XP (same dev license).
Please can someone from the license team help urgently?
Thanks.
Hello Mike,
If you navigate to "C:\Windows\assembly" do you see the Infragistics.License assembly listed? If not, re-run the installer as an administrator and make sure you enter your product key correctly.
The above link no longer works.
I am getting Build error: "NetAdvantage For Win Forms Trial Period Expired" on Windows 7.
If you have UAC enabled, you may need to disable it since the installers from 2006 were before Windows Vista was released. There are more details on installing on Windows Vista in the following knowledge base article and this will apply to Windows 7 as well:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=9983
Let me know if you have any questions with this matter.
