Hello!
I have some suggestions for the online documentation: http://help.infragistics.com/NetAdvantage/NET/2007.3/CLR2.0/ whereby I am only talking about the CSO-parts (I only use it for them).
I think it schould be overworked because for example the entry for client-Side Event "AfterEnterEditMode" of the WebGrid does not tell me that it can be abortet by returning true
Further more I think there schould be much more examples for probably more difficult functions.
And a Problem with mozillas firefox: if I resize the window, containing the online help, the scrollbar of the tree and the webtab disappear (I think the horizontal size of the tree increases and the overflow is switched off).
Philipp
Since one year no changes... ridiculous
Just for recalling, this was the answer on 03.06.2008:
"In terms of the online help application in Firefox, we are aware of several issues with the program in Firefox, and are currently in development of a new version that should eliminate all these browser issues."
The similarities are overbearing.
We are currently aware of this issue regarding FireFox and will be fixing it in a future update. Please note below the reference to the issue posted within the documentation. This is under the section "Known Issues and Limitations in the Help", sub-section "Web Browser Support".
There is no vertical separator between the left-hand and right-hand window panes. This prevents you from being able to resize the left-hand window pane.
-- Lance
Lance Spence"]First I apologize for you having an unpleasant experience with the online documentation. Could you please provide a specific link within the documentation that is not working for you as well as the associated product? I went through a number of the links using FireFox 3.0.4 on Vista and was unable to find any that were broken.
Sorry, I will try to be more precise. It appends in fact on each page I open from the search result window (which is the only way for me to open documentation since the treeview does not display completly). I also notice that images ans icones are broken. It is probably a base url problem.
For example, a search on "ultragrid" drive me to the url http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR2.0/html%5CInfragistics2.Win.UltraWinGrid.v8.2~Infragistics.Win.UltraWinGrid.UltraGrid_members.html which has broken links and image (see attached screenshot). The first link (for example) points to the non existing url: http://ko.infragistics.com/support/documentation_not_found.aspx?URL=http://help.infragistics.com/scripts/PageNotFound.aspx?HttpCode=404?404;http://help.infragistics.com:80/Help/NetAdvantage/NET/2008.2/CLR2.0/Infragistics2.Win.UltraWinGrid.v8.2~Infragistics.Win.UltraWinGrid_namespace.html
Thank you for taking care of this problem
I'am using firefox 3.04-FR on windows XP sp3
As you can read in the first post, the tree is not resizing properly (screenshot) there is no vertical scrollbar.
It's Win XP SP3, firefox 3.0.4 german.
