Hi ,
how can i attach sample application with my post?
Jafar VM
Jafar,
It should be fixed now for you. And you should be able to add attachments now.
Hi Jafar,
Is it your post, or you tried to attache the sample on existing post?
If it is yours you can unlock it by unchecking the “Locked” field. I will double check if everything is fine with your account and get back to you.
Hi Dimi,
Thanks for ur post,when i take option pane there is no buttons.there is only a checkbox and text message like "Locked."
You can attach your file to the forum when write your questions go to “Options” tab and use “Add/Update” button.
See the image.
