Error 418 Z:\Inetpub\wwwroot\eTOMS\licenses.licx: Could not transform licenses file into a binary resource. Index (zero based) must be greater than or equal to zero and less than the size of the argument list. Z:\Inetpub\wwwroot\eTOMS\licenses.licx Z:\...\eTOMS\
I just upgraded from 11.1 to 12.2. I have one project that I decided to change everything to 12.2. I reloaded the Bin folder with the correct dll's and now I get this error. What else am I missing?
The current error doesn't sound related to the Infragistics controls so I am not sure if I will be much help. I did do a Google search and found the following question on StackOverflow which may be related:
http://stackoverflow.com/questions/806449/asp-net-network-bios-command-limit-has-been-reached-asp-net-2-0-3-5
Let me know if I may be of further assistance.
Thank you again for your help. If have it compiling but it won't run. I get the BIOS command limit has been reached error...
I know, I don't think this is something you need to help with. Thanks.
Yes, that did work. Not I am getting weird aspx javascript errors with my functions. Very strange. Error 12 'ASP.odc_editodc_aspx' does not contain a definition for 'fnDisapprovalCheck' and no extension method 'fnDisapprovalCheck' accepting a first argument of type 'ASP.odc_editodc_aspx' could be found (are you missing a using directive or an assembly reference?) Z:\Inetpub\wwwroot\eTOMS\ODC\EditODC.aspx 624
I still have my method.. But thanks for the response.
Have you tried to clean the project/solution and rebuild? If not this may resolve the error.
