255
Can't install trial version
I'm having trouble installing the trial software for evaluation. I tried this on two different computers. The install dialog says there were errors. It said to check the internet connection and then retry. Here is a portion of the log file. I tried this running as Administrator, as well. I checked the internet connection and yes it was connected.
09:08:29: Log file initialized at: 2/28/2014 9:08:29 AM
09:08:29: Version number of the executable is:
13.2.20132.1057 09:08:32: Checking proxy settings...
09:08:32: Proxy found on the system!
09:08:32: System.UnauthorizedAccessException: Access to the path 'C:\ProgramData\Infragistics\13.2\Infragistics_20132_Platform.exe' is denied.    at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)    at System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite)
