100
Error while installing Infragistics Ultimate 2013.2 trail version
Hi Team,
Installation of 13.2 throws below exception we are using 'Infragistics_20132_PlatformInstaller', if we select full installation then its shows that ‘Windows Phone 7.1’ and ‘Silverlight 5.0’ dependency is missing. We have ‘Windows Server 2008’ operating system and ‘VS 2010’,  we experiences that  ‘Windows Phone 7.1’ does not support ‘Windows Server 2008’ operating system and it ask for Windows Vista, however we have selected only asp.net options in Infragistics setup and continue further steps and it throws below error.
 Error:
02:39:52: Version number of the executable is: 13.2.20132.1057
02:39:57: Checking proxy settings...
02:39:58: Proxy not found on the system!
02:40:20: Error has occured while downloading product configuration from server.
02:40:20: System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 64.14.177.234:80
   at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
   at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Int32 timeout, Exception& exception)
   --- End of inner exception stack trace ---
   at System.Net.WebClient.DownloadFile(Uri address, String fileName)
   at System.Net.WebClient.DownloadFile(String address, String fileName)
   at Infragistics.Wrapper.Interface.Utilities.AutoUpdatesUtility.UpdateRTMDownloadUrls()
02:40:41: Error has occured while downloading product configuration from server.
02:40:41: System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 64.14.177.234:80
 Please let us know if you need more details.
