I recently upgraded VS 2010 to VS 2013 simultaneously installing Infragistics 14.1 trial version where I had 13.2 version purchased. I am able to use the version utility tool to update my projects to 14.1. The web projects run in dev and publish to prod fine. My issue is the controls in the IDE are not formatting. I have uninstalled VS 2010 and uninstalled all Infragistics versions before 14.1 then I reinstalled 14.1 which didn't resolve the issue. I uninstalled VS 2013 and Infragistics 14.1 then reinstalled them. I used the 14.1 Version Utility on my solutions before launching VS 2013. The issue persists.
Note: after uninstalling 13.1 and 13.2 they still appear in the VS 2013 tool bar as Platform Installer options.
Any guidance would be appreciated.
Hello Viggen2002,
I am glad we were able to help you to resolve the issue.
If you need any further assistance do not hesitate to contact us.
Elizabeth Albert"] Hi Viggen2002, It looks like the project can't find the "ig_res" folder.
Hi Viggen2002,
Although the folder was there some link was broken during the upgrade to either VS 2013 or 14.1. My solution was delete the existing ig_res folder then re-import a new ig_res default and IG. Voila!
Thank you,
Is the ig_res directory included in your project and if it is could please provide how it is registered in you webconfig?
It looks like the project can't find the "ig_res" folder. Could you please verify that there is an "ig_res" folder in your project?
This should be done automatically when creating a project, but I've had this happen when opening a project where the extra folders (bin, obj, ig_res) were removed. In that case, it should prompt you the first time you switch to design view to add the "ig_res" folder.
For more information on manually adding the "ig_res" folder, please refer to this help topic.
Elizabeth AlbertLocalization Engineer
This is how webdatagrids are displaying even thought the StyleSetName is set to "IG":
