Does the latest Ignite UI for angular support Bootstrap 4? I see code samples use Bootstrap 3.1.1.
Yes it does, although Ignite UI for Angular framework is following Material Design conventions and using of Bootstrap styling would change the entire look and feel that we are following. Material Design is a visual language that synthesizes the classic principles of good design with the innovation and possibility of technology.
