2575
igxGridColumnComponent programatically set the width of a column
Is it possible to set the width of certain igxGrid columns programmatically? I'm allow the grid to auto-generate the columns, but by default they're not wide enough to show the header text and sometimes the content, so I tried the following:
  onColumnInit(column: IgxColumnComponent) {
    console.log(column.field)
    if (column.field === 'Timestamp')
      column.width = '400px'
This doesn't seem to affect the column width. Is this possible to do on auto-generated columns?
  • 320
    Verified Answer
    Hello John VanZwieten,
    Thank you for contacting Infragistics Support.
    Yes it is possible, but there was a bug in our latest version 5.1.3, that has been already addressed and resolved in our 5.2.0 beta release. So I am sending you a zip file with sample project that use our latest release (5.2.0-beta.1) and resolves your issue. It is very important to notice a few changes that are required to do when you set up a new project with our latest version (5.2.0-beta.1):
    in file angular-cli.json you should add:
    "apps": [
          "root": "src",
          "styles": [
            "styles.css",
            "../node_modules/igniteui-angular/styles/igniteui-angular.css"
    and in your styles.css  if you want to use material-icons, you should add
    If you need any further assistance, please contact us.
    Best Regards,
    Desislava Dincheva
    Associate Software Developer
    Infragistics, Inc.1732.igxGrid.zip
