90
Issues with igx-grid
1. Filter
If my grid is not tall enough, the filter gets cut off
What can I do to fix this?
 2. Virtualization
It seems that vertical virtualization is based on the scroll bar position rather than data set size, which requires the grid height to be set.
This would look very ugly if the data does not fill up the height of the grid.
Is there any way to set virtualization on based on dataset size?
 3. Master/Detail grid
Can I get a sample on how to set up a master detail grid?
e.g.
  • 18204
    Suggested Answer
    Hello Yash,
    Thank you for posting in our forums!
    To resolve the filter height issue, you can use the following CSS to show your filter.
    igx-grid.igx-grid {
      overflow: visible !important;
    Regarding virtualization, it can only be set by setting the height of the grid.
    The current grid version does not have hierarchical and tree grid features.  To enable a Master/Detail setup, you will need to create two IgxGrids, one for Master and one for Details.
    If you need any further assistance with this, please let me know.
