Hii
I am using igx-calender for booking app, I want past dates to be disabled eg today is 7/7/2018 so all past dates eg 1/2/3/4/5/6 must be disabled ,
how can I archieve that using igx-calendar? any example or tutorial , thanks
Hi Aleksandar, any updates on this feature?
Hi Jim, I'm just starting out on this, but there is an event , onSelection() that you can see what date they picked and reject it if you want. The example is in the Calendar component. Might work for you for the moment.
Jerry
Hello Jim,
I think I get it what you mean.
We are always trying to be trendy and to take all problems into account but it seems that we do not always succeed. That's why we have customers like you which are enough proactive to emphasize the problem that is found and to take responsibility of informing us.
Thanks again for the logged issue and for the detailed description you have added.
As our product owner said we are going to take action on it after the end of July and will update the issue accordingly.
If you have further questions please contact us again.
Hii Aleksandar
Here is the link to the issue, hope they will work on it, something easy and must be on any calendar ui, wheather you like it or not , to be success you must look what others do, what is trending right now etc, if you go p-calendar from primefaces u can see what I mean, car is a car but a car without a break is not a car is something else
https://github.com/IgniteUI/igniteui-angular/issues/1980
For now there is no such functionality. I can propose you to log an issue as feature request here.
There is detailed information of how the issues should be logged. You can find it here.
I want to assure you that the issues logged from customers with such common scenarios are tracked as priority. So the sooner you log the issue the sooner it would be fixed.
If you have any further questions, please contact us again.
