250
How to bind string date to IGXDatetime picker
hello,
i have a gird with one column as  date type with editable enabled.every thing is fine but problem occures when i bind the grid to the data from webapi, as from back end i m passing date in yyyy-mm-dd format and after binding  no date is visible on grid and i m unable to select date
following error msg occurs,
ERROR TypeError: value.toLocaleDateString is not a function
at IgxDatePickerComponent.push../node_modules/igniteui-angular/fesm5/igniteui-angular.js.IgxDatePickerComponent._setLocaleToDate (igniteui-angular.js:23410)
at IgxDatePickerComponent.push../node_modules/igniteui-angular/fesm5/igniteui-angular.js.IgxDatePickerComponent._customFormatChecker (igniteui-angular.js:23425)
at IgxDatePickerComponent.get [as displayData] (igniteui-angular.js:23120)
at Object.eval [as updateDirectives] (IgxDatePickerComponent.ngfactory.js:102)
at Object.updateDirectives (core.js:10806)
at checkAndUpdateView (core.js:10459)
at callViewAction (core.js:10700)
at execComponentViewsAction (core.js:10642)
at checkAndUpdateView (core.js:10465)
plzzz help.
  • 16310
    Hi Alok,
    You need to pass a real date object to the component. It will not parse any string values. The same applies for the igxGrid. Please let me know if you have further questions.
