Hi
Is there a way to set the background color of rows based on a particular column value? Odd-even setting would not be of much help for me here.
B.
Hello,I have built a small sample, where i changed the background color for every cell from specific row, where one column value match a specific criteria. Please take a look at the sample and do not hesitate to ask if you have any additional questions.
I am not able to change whole row back ground color in igx grid based on column value. Could you please provide me an example.
Hi there,
Just letting you know that this functionality was made available with one of our releases. You can check it out here:
https://ko.infragistics.com/products/ignite-ui-angular/angular/components/grid_conditional_cell_styling.html
Thank you for using Ignite UI for Angular!
Konstantin Dinev
Thank you. I hope this is something that will be available in the upcoming versions.
Hello,Thank you for contacting Infragistics Support.
Currently, we do not provide a way to set a custom classes for specific row, so it is not possible to set a style to specific row based on particular cell value (I guess by column value you mean cell value), you can only define a custom template and style for a specific cell. If I did not correctly catch up your case please provide more detailed information about it in order to be able to help you. You can also log an issue as a feature request in our GitHub repository and we will review and start work on it as soon as possible.
If you need any further assistance, please contact us.
