I was wondering if someone can point me to some resources or provide some insight on my problem.I have a large Data Table which i get from a NodeJs server in Json Format which works fine and scrolling etc works. Problem i have is when i go and want to export the data it will only export the visible rows notall rows which match my Data Result. Is there a way to call the Export function to get all data rather thenonly export whats on page ? also is there an option for Angular to export it to PDF without going thru excel and the print to PDF ?
Agreed with Jerry below...what in the world does 'CAS-198632-Z1J5M0' represent? How does this help us?
Can you post that somewhere public ? I can't find CAS-198632-Z1J5M0 anywhere
Thank you for contacting us!
To export all rows you have to set all the grid data to be exported with the approache demonstrated in CAS-198632-Z1J5M0.
About the question for the PDF exporting, the Igx-Grid doesn't provide PDF exporter.You can log a an issue about the requested functionality in our repository and set it "feature request" label.
Let me know if you have any further questions.
