15
API call too slow , can I put a spinner inside the grid until the data shows up? or maybe I can do Igx-toast ?
I do not have control over my DB so the GET request takes about 8 seconds to bring a response from the server. On a normal HTML/JS table, usually I put a spinner on the middle of table until the table loads. could this be possible on Igx-grid?...or maybe I can use Igx-toast until the data loads?
  • 5105
    Hi Gerald,
    On top of what Radko suggested, you can use a toast, temporarily, to display a loading message. We've put an indeterminate progress indicator component on the backlog and will soon ship one, so you would be able to replace the toast with it in the near future!
    Thank you for using Ignite UI for Angular!
    Konstantin Dinev
  • 2151
    Hello Gerald,
    If you bind the IgxGrid initially to an empty array it will display a no-data-message which is configured using the IgxGrid's "emptyGridMessage" property. You can put there a string value, for example "Loading...". Later when you populate the array with data the message will disappear. Alternatively you can use a toast with “autoHide” set to false and this way you can control when exactly it is shown and hidden. I am attaching a sample showing both approaches.
    If you require any further assistance on the matter, please let me know.
    Sincerely,
    Radko Kolev
    Senior Software Developer
    4101.GridLoading.zip
