Hi guys,
In case you didnt notice your demo project have some issues:
IgxIconComponent: 'iconName' property is deprecated. To set the icon name for 'material' icons place the name of the icon between the opening and closing tags. For 'Font Awesome' and SVG icons use 'name' property.IgxComboComponent: Setting combo item template with '#emptyTemplate' is deprecated.Use `igxComboEmpty` directive instead.IgxComboComponent: Setting combo item template with '#headerTemplate' is deprecated.Use `igxComboHeader` directive instead.IgxComboComponent: Setting combo item template with '#footerTemplate' is deprecated.Use `igxComboFooter` directive instead.IgxComboComponent: Setting combo item template with '#itemTemplate' is deprecated.Use `igxComboItem` directive instead.IgxComboComponent: Setting combo item template with '#addItemTemplate' is deprecated.Use `igxComboAddItem` directive instead.IgxComboComponent: Setting combo item template with '#headerItemTemplate' is deprecated.Use `igxComboHeaderItem` directive instead.IgxDatePickerComponent: 'igx-datePicker' selector is deprecated. Use 'igx-date-picker' selector instead.Function: IgxGridModule.forRoot method is deprecated. Use IgxGridModule instead.** Angular Live Development Server is listening on localhost:4200, open your browser on http://localhost:4200/ ** 0% compiling[16:07:39] 'generate-live-editing' errored after 5.74 s[16:07:39] Error: Function igx-input-group-theme has no parameter named $variant at Object.module.exports.renderSync (C:\various\igniteui-angular-samples-0.0.4\node_modules\node-sass\lib\index.js:439:16) at SassCompiler.compile (C:\various\igniteui-angular-samples-0.0.4\live-editing\services\SassCompiler.ts:21:45) at SharedAssetsGenerator._generateSharedAssetsWithCSS (C:\various\igniteui-angular-samples-0.0.4\live-editing\generators\SharedAssetsGenerator.ts:57:31) at SharedAssetsGenerator.generateSharedAssets (C:\various\igniteui-angular-samples-0.0.4\live-editing\generators\SharedAssetsGenerator.ts:34:22) at LiveEditingManager._run (C:\various\igniteui-angular-samples-0.0.4\live-editing\LiveEditingManager.ts:22:48) at LiveEditingManager.run (C:\various\igniteui-angular-samples-0.0.4\live-editing\LiveEditingManager.ts:16:18) at Object.<anonymous> (C:\various\igniteui-angular-samples-0.0.4\live-editing\LiveEditingManager.ts:27:26) at Module._compile (internal/modules/cjs/loader.js:688:30) at Module.m._compile (C:\various\igniteui-angular-samples-0.0.4\node_modules\ts-node\src\index.ts:422:23) at Module._extensions..js (internal/modules/cjs/loader.js:699:10)(node:20052) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! igniteui-angular-samples@1.0.0 generate-live-editing: `gulp generate-live-editing`npm ERR! Exit status 1npm ERR!npm ERR! Failed at the igniteui-angular-samples@1.0.0 generate-live-editing script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:npm ERR! C:\Users\SV\AppData\Roaming\npm-cache\_logs\2018-12-04T14_07_39_426Z-debug.logERROR: "generate-live-editing" exited with 1.npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! igniteui-angular-samples@1.0.0 start: `npm-run-all -p serve generate-live-editing`npm ERR! Exit status 1npm ERR!npm ERR! Failed at the igniteui-angular-samples@1.0.0 start script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:npm ERR! C:\Users\SV\AppData\Roaming\npm-cache\_logs\2018-12-04T14_07_39_641Z-debug.log
Using Angular 7, CLI 6.1.5, npm 6.4.1, node 10.12.0, WebStorm IDE 2018.3 on a Windows machine.
I'm not in a desperate need the project to be fixed - i'm just comparing IgniteUI vs KendoUI as a developer, so i'm just pointing out that the provided product is a bit buggy. Maybe its a minor fix - i didn't investigate at all.
Cheers,
Svilen
You're welcome!
Thanks for the quick response Martin! :)
Hello Svilen,
We also tagged a new version of the igniteui-angular-samples which fixes the issues you saw. You can grab it from here.
Best regards,
Martin Pavlov Infragistics, Inc.
When you did `npm install` on the latest version of the igniteui-angular-samples it installed igniteui-angular 6.2.3 package. This package version has some breaking changes compared to igniteui-angular 6.2.0, that's why you see these errors.
One way to resolve the issues is to execute `npm install igniteui-angular@6.2.0`. The other is to grab the latest source code from master branch.
Best regards, Martin Pavlov Infragistics, Inc.
