I have a date and time picker set up like this sample. I now want to make these required as well as disable the submit button when they are not filled in (I know how to do this). Default the fields will be blank. I tried with adding the "required" property onto the input field but that keeps marking the field as invalid. Is it possible to achieve this another way and if so how?
Hello Nina,
We are glad most of the issues are resolved now and the workarounds are no longer needed.
This last issue you are experiencing is caused by the fact the inner input is bound to 'displayData' and not to 'value'. In general, this should be perfectly fine, but our internal logic currently changes the editor's displayData property value to an empty string even when no date value is set which triggers the validation. We logged this issue and it will be resolved in the component in our next version. Temporarily, you may tweak a little your code in 2 ways, so it does not surface in your application. The two options are:
- Change the binding from [(ngModel)]="displayData" to [(ngModel)]="displayData || startDate";
- Bind to a custom property which formats the date as per your requirements.
Both approaches I implemented in this updated sample.
Please, let us know if you need further assistance on the matter.
Hi Galina,
It seems I misunderstood some things about the ngModel. I'm now using this on the inner date inputs which solves a few problems and drops the need for some workarounds. In fact I think I now got it working correctly except for one thing: When the form loads the date fields are immediately marked as invalid. Is it possible to have them empty but without being already validated, like the required name field? Here is a new demo.
Thank you for your patience. If you want to avoid using ngModel on the inner date input which is how controls get registered with the form so they get validated appropriately, I can recommend manually updating the valid value of the input as shown in this updated sample application.
We were wondering if there has been any progress on this since it has been a few days since we've had a reply. Is the provided demo working and clearly showing the problem?
This has helped me a little but I'm still facing some issues.
Here is the correct link for the current version of my problem: https://stackblitz.com/edit/datepickerdemo
What has been added is the requirement that the form is invalid and cannot be submitted if the endDate comes before the startDate. I wrote a directive for this and put it on endDatePicker (it doesn't fire when I put it on the endDate input field in the template). I can see the directive work because if we set startDate to today and endDate to some days ago, the submit button becomes disabled, and also there is some info being printed to the console. But the endDatePicker does not get any invalid styles.
