I want to add row action column to IgxGridComponent before it is rendered, my requirement is not to use ngFor.
I have added my custom directive on <igx-grid> which will be adding this dynamic column.
Thanks in Advance.
I tried:
Hi Shahab,
The static columns can still be declared as a static configuration in the component, and the configuration can then be augmented with the dynamic column.
I made a small stackblitz example of how I turn this sample:
https://ko.infragistics.com/products/ignite-ui-angular/angular/components/grid_paging.html
Into a sample with columns defined in configuration, and an dynamic column that is being added with a button:
https://stackblitz.com/edit/angular-1v1k8m
Konstantin Dinev
Hi Konstantin,
all of my columns are static, there is just one column which I want to add dynamically every time.
You need to use *ngFor in order to do this. If you can provide your component code and your template, I can assist you to move your columns configuration to a collection you can *ngFor on top of.
Thank you for using Ignite UI for Angular!
Sincerely,
