30
Column Order
I was wondering if there is a way to specify the column order in an excel spreadsheet when exported as the json output from my webservice might return the data not in the desired format. Also is there a way to format column like money etc ? Last one can the Header name be set to something else then the field name of the json doc ? for example i have a field called customer_name and i want in the header to show Names ?
