I came across another issue, when i pass the output of my query which is the below sample i get [object Object],[object Object],[object Object] in the emails column. How can i fixed that or does exporter have no way of handling arrays in a field ?
{ "DocId": "farm::4DA8DC94-D10B-4962-A920-775F0A86FB5A", "baths": 2, "beds": 2, "city": "Los Angeles", "emails": [ { "default": "demo1@test.com" }, { "default": "demo2@test.com" }, { "default": "demo3@test.com" } ] }
Thanks for taking the time to check the example!a) You can pass `arrangeData` inside of the `exportData` call and transform function through Array.map of the array you want to change:
this.excelExportService.exportData(this.localData.map(e => arrangeData(e)), new IgxExcelExporterOptions("ExportFileFromData"));
b) An oversight, sorry for the confusion. It's now fixedc) You can again transform the data you want to be output in the export file. In the case of $25.00, you can do:
(e: number) => '$' + e.toFixed(2);
You can also refer to my reply in your other thread regarding the difference between the ExcelExporterService and the Excel Library.
Hope this helps!
Thanks, that gets me closer but here are some additional questions...
a) Is there a way to pass the Arrange data dynamically, when calling the export function
b) Not sure what this part is doing in the sample code
this.excelExportService.onColumnExport.pipe(takeUntil(this.destroy$)).subscribe((args: IColumnExportingEventArgs) => { if (args.field === "name") { args.header = "Name" } })
i assumed it would change the column Header from name to Name. If that's the case that's not working
c) lets say i am your example which we have as age is actually money and i would show it on the excel export as $ 25.00 for example how would i do that and how can i pass format info for certain fields dynamically
I am trying to create a module which will be able to be reused and does not have to be specific for a single export which means i want to be able to pass the column to export, column order, heading as well as column format when calling the export function. Also i hope the same concept as far as transformation apply s to the csv export
Hi Alex,Thank you for contacting Infragistics!You can modify the data in the row by attaching to the `onRowExporting` event of the `IgxExcelExporerService`.In this case, you can define a transform function that reduces your e-mail array to a string:
const formatEmails: (arr: { "default" : string }[]) => string = (arr: { "default" : string }[]) => arr.map(e => e["default"]).reduce((e, i) => e + i + "; ", "");
Then, when exporting, subscribe to the `onRowExporting` event and transform the data inside the 'emails' field:
this.excelExportService.onRowExport.pipe(takeUntil(this.destroy$)).subscribe((args: IRowExportingEventArgs) => { args.rowData["Emails"] = args.rowData["Emails"].map(e => e["default"]).reduce((e, i) => e + i + "; ", ""); })
Here is a working StackBlitz example you can check out.Hope this helps!
