Following on from this question and the provided sample:
https://ko.infragistics.com/community/forums/f/ignite-ui-for-angular/119273/way-to-compose-column-data/529739#529739
https://stackblitz.com/edit/angular-ea5meq
In the example where the grid is bound to the nested data source, I am looking for ways to implement Filtering, Sorting & Grouping on a similar column where an ng-template is used for the grid column and the column is bound to an object.
Can anyone provide an example where this is implemented, or extend the above sample to demonstrate?
Hi Mark,
I have created a sample demonstrating how to do Filtering on such a column in the igxGrid, please feel free to explore it here.
What is important to note is that I have bound an external input for filtering the data, instead of using the default UI, which I am not sure would be achieved ( will confirm later).
In the input change event, we need to:
1) create a filtering expressions tree, based on the value entered and filter the data collection using those expressions
2) Pass the filtered data to the grid
public filter(term) { const filtExpressionsTree = new FilteringExpressionsTree(FilteringLogic.Or); filtExpressionsTree.filteringOperands = [ { fieldName: "name", condition: IgxStringFilteringOperand.instance().condition("contains"), searchVal: term}, { fieldName: "email", condition: IgxStringFilteringOperand.instance().condition("contains"), searchVal: term } ]; const state: IFilteringState = { expressionsTree: filtExpressionsTree, strategy: new SimpleFilteringStrategy() }; const filteredData = DataUtil.filter(this.nestedData, state); this.grid1.data = filteredData; } }
Will update you later with details on how to implement the sorting as well.
Hristo
Hi Hristo,
Thanks for providing the sample.
I am also interested in filtering by a single property of a column bound to an object using the grid UI. I have seen a way to do this in the below question and sample:
https://ko.infragistics.com/community/forums/f/ignite-ui-for-angular/119621/default-filtering-with-ng-template
https://stackblitz.com/edit/angular-hyy2sb-zzmxdu
I am now looking for a way to extend this UI filtering sample to make the CustomStringFilter reusable across string properties with different names.
Currently the sample filter is set to look for a field called 'link'. It would be good if this could be modified to take an object and a string containing the name of the property to filter by.
Appreciate I would need different logic for e.g. filtering strings and dates but would like to reuse the filtering logic for the same data types instead of creating separate similar filters for many different grid columns across my application.
I am looking for a flexible, reusable way to filter/sort/group a column where an object and the name of a single object property to use can be provided to custom filtering/sorting/grouping logic.
Mark
Hello Mark,
The sample that you shared demonstrate the other way to achieve filtering on a column, whose value is compound of other columns` values. As you see it is not that effective to use it, as you need to implement all conditions for the custom operand, while the only thing that is changed in regards to the default conditions is the logic method.
The ideal way to solve this issue would be the ability to provide a custom filtering strategy per column and I am going to log this as a feature request in our product, and I will provide you with the link to the issue. Meanwhile I will try to find other ways to improve this approach in order not to hardcode values like "link" and achieve reusability.
I will keep you posted.
I have updated the sample to do Sorting and Grouping on the use column, based on the registered value of the user:
https://stackblitz.com/edit/angular-cscspe
Please note that to achieve the above, is required to:
1) Define a custom sortStrategy, that extends the DefaultSortingStrategy. We need to override the compareObjects method, to work with the "registered" field of the object. Also, define a custom groupingComparer function for the column, that will work with the "registered" field of the object
2) Set the custom strategy and groupingComparer inputs for the column:
Please let me know if you have further questions, I will be glad to help!
Thanks for the update. I've also been working on this and have another approach which seems to work for me at the moment.
For example in my application I have a "client".
First define a class for the data which will be bound to the column and override the toString() method.
Then map data from the API to the class before binding to the grid column.
This way I am able to use the built in sorting, filtering and grouping functions of the grid, so I don't have any repeated code for the various strategies that are otherwise required. This approach also removes the need to use an ng-template for displaying the cell. For editing I am using an ng-template with an igx-select component.
I think your example with the custom strategies will also be useful for more complex scenarios.
Do you have any comments on my approach, or any reason not to use this approach with the Ignite UI components?
