815
Adding compents to an existing application with only a Trial License
We are attempting to add the Ingite UI for Angular to an existing application as a proof of concept to swap out the UI.  The Samples installed and functioned with no issue but when we attempted to run the command shown below we encountered the message about providing Infragistics Account Credentials.  Is it possible add these tools to an existing application with only a trial license?
PM> ig add hierarchical-grid InventoryGrid
√ View 'InventoryGrid' added.
The project you've created requires the full version of Ignite UI from Infragistics private feed.
We are initiating the login process for you. This will be required only once per environment.
Adding a registry user account for https://packages.infragistics.com/npm/js-licensed/
Use you Infragistics account credentials. "@" is not supported,use "!!", so "username@infragistics.com" should be entered as "username!!infragistics.com"
