50
IgxGrid isLoading is working only the first time
I'm not sure I correctly understood how isLoading is working
I got a grid that looks like this :
<igx-grid #f6Grid [data]="opaleForms$ | async" [isLoading]="isLoading$ | async>
<igx-column [resizable]="true" [field]="'Code'"></igx-column>
Some other columns...
</igx-grid>
The situations goes like :
  • View is loaded and everything is displayed with empty values (ie : The grid is here with the column but not values in it)
  • The user click on search button
  • The isLoading is set to true
  • The grid is displaying the spinner (loading works )
  • The data is returned, the isLoading is set to false
  • The grid is displaying data and not the spinner (still good )
  • The user click again on the search button to search something else
  • the grid is not displaying the spinner (not working )
Am I doing something wrong or is it supposed to work like that ?
PS :
isLoading$ | async is used with NGRX store
I tried with a simpled value (isLoading) and I changed it manually but I still had the problem
Tell me if you need a repro, I should be able to make a stackblitz
